Displays static MLD snooping entries.
name | Specifies a VLAN name. |
None.
Use this command to display the MLD snooping static groups or router ports configured on the specified VLAN. When no VLAN is specified, all the static groups or router ports are displayed.
The following command displays the MLD snooping static groups configured on VLAN vlan101:
show mld snooping vlan101 static group
The following is sample output for this command:
Group Port Flags ff03::1:1:1 7 sa ff03::1:1:1 15 sa Flags: (s) Static, (a) Active
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
